Oggi è mer apr 24, 2024 23:22
 Oggetto del messaggio: Aiuto per script (trova centro di un pieno)
MessaggioInviato: gio gen 17, 2013 21:46
Serve per trovare il centro di un tondo pieno.
Quando lo lancio mi dà errore...
Probabilmente la soluzione sta nelle prime quattro righe qui sotto (lo script è sicuramente funzionante).
Non capisco cosa vuol dire che devo linkare un bottone...
Poi ancora non capisco cosa devo "engaggiare"...
Grazie a chiunque avrà la cortesia di rispondermi.
Carlo
This is the "Shaft" extract
To run it you have to link to a user button or include in yours other functions.
Take care, when you run the shaft procedure, a check is made to be sure that the gauge is not already engaged, than to continue the operation you must engage it (ground it like a push button).
'find shaft center and calculate diameter
Sub Shaft
Option Explicit
Dim TS As Single
Dim FeedCurrent, Xcurrent, Ycurrent , Zcurrent As Single
Dim XCenter, YCenter, XPos1, XPos2, YPos1, YPos2, XNew, YNew, ZNew, ZPos1,ZSafe As Single
Dim responce As Integer
Dim Max_move , Shaft_D As Double
Const ZClear = 10 'Safe Z
Const XMove = 4 'Max probe search
Const YMove = 4 'Max probe search
Const FSlow = 50 'edje search speed
Const Tout = 15 'Time out in seconds
Const Probe_Radius = 3.15 '
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
Code "(Probe grounded, check connection and try again)"
responce = MsgBox ("Probe grounded, check connection and try again" , 0 , "Probe **ERROR**" )
Exit Sub
End If
Rem VBScript To shaft center
Max_move = Question ("Enter max shaft diameter, min value 1 mm")
If Max_move < 1 Then
Code "(Diameter < 1, Function abort)"
Exit Sub
End If
If Touch ("(Touch the Probe to start Shaft center function)") Then Exit Sub
Code "F" & FSlow
Rem Probe up
YNew = YCurrent + Max_move
Code "G31 Y" &YNew
While IsMoving()
sleep 100
Wend
YPos1 = GetVar(2001)
YNew = YPos1 - 0.5
Code "G0 Y" &YNew
ZNew = ZCurrent + ZClear
Code "G0 Z" &ZNew
YNew = YPos1 + Max_move + (Probe_Radius * 2) + 2
Code "G0 Y" &YNew
Code "G0 Z" &ZCurrent
Rem Probe down
YNew = YNew - Max_move - Probe_Radius
Code "G31 Y" &YNew
While IsMoving()
sleep 100
Wend
YPos2 = GetVar(2001)
YNew = YPos2 + 0.5
Code "G0 Y" &YNew
Code "G0 Z" &ZNew
YCenter = (YPos1 + YPos2) / 2
Code "G0 Y" &YCenter
Rem Probe Left
XNew = XCurrent - Max_move - (Probe_Radius * 2) 'probe to left
Code "G0 X" &XNew
XNew = XNew + Max_move + Probe_Radius
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
sleep 100
Wend
XPos1 = GetVar(2000) 'get the probe touch location
XNew = XPos1 - 0.5
Code "G0 X" &XNew
Code "G0 Z" &ZNew
Rem Probe Right
XNew = XPos1 + Max_move + (Probe_Radius * 2) + 2 'probe to right
Code "G0 X" &XNew
XNew = XNew - Max_move - Probe_Radius
Code "G31 X" &XNew
While IsMoving()
sleep 100
Wend
XPos2 = GetVar(2000)
XNew = XPos2 + 0.5
Code "G0 X" &XNew
Code "G0 Z" &ZNew
XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
Code "G0 X" &XCenter 'rapid move to the x center location
While IsMoving ()
sleep 100
Wend
Shaft_D = (XPos2 - XPos1) - (2 * Probe_Radius)
Code "(Shaft diameter = " & Shaft_D & " mm)"
Code "F" &FeedCurrent 'restore starting feed rate
End Sub
'Wait for a probe touch - untouch
Function Touch (Tshow As String) As Integer
Code Tshow
'wait probe touch
TS = Timer
Do
If Timer - TS > Tout Then
Code "(Function Time Out, no probe touch detected)"
responce = MsgBox ("Function Time Out, no probe touch detected" , 0 , "Probe **ERROR**" )
Touch = 1
Exit Function
End If
sleep 100
Loop Until GetOemLed (825) <> 0
'short delay
sleep 1000 'let user to untouch probe
'Wait for probe untouch
TS = Timer
Do
If Timer - TS > 2 Then
Code "(Function Time Out, continuous probe touch detected)"
responce = MsgBox ("Function Time Out, continuous probe touch detected" , 0 , "Probe **ERROR**" )
Touch = 1
Exit Function
End If
sleep 100
Loop Until GetOemLed (825) = 0
Touch = 0
End Function
 Oggetto del messaggio: Re: Aiuto per script (trova centro di un pieno)
MessaggioInviato: gio gen 17, 2013 21:50
passo , ma credo che ti chieda di portare il tastatore in posizione e poi lanciare il programma .
MessaggioInviato: gio gen 17, 2013 22:35
Meno male che ha risposto Rino altrimenti cancellavo il messaggio pensando fosse SPAM :rotfl:
MessaggioInviato: gio gen 17, 2013 22:38
:rotfl:
MessaggioInviato: gio gen 17, 2013 23:51
Io questi scherzi non li capisco...
Come è possibile pensare che sia spam?
MessaggioInviato: ven gen 18, 2013 00:00
Forse ti è sfuggito che Max scherzava...
MessaggioInviato: ven gen 18, 2013 19:36
secondo me voleva solo dire che il testo gli era incomprensibile.
avc
MessaggioInviato: ven gen 18, 2013 21:23
Esatto :mrgreen:
MessaggioInviato: sab gen 19, 2013 13:04
A chi posso chiedere aiuto?
Probabilmente lo script è giusto.
Io quando lo lancio ottengo il messaggio errore di compilazione...
Non so a chi posso rivolgermi...
Qualche consiglio?
Carlo
MessaggioInviato: sab gen 19, 2013 19:03
Risultato delle mie fatiche
https://dl.dropbox.com/u/36638541/trova_centro.mp4
MessaggioInviato: sab gen 19, 2013 19:07
spiega come hai fatto?
MessaggioInviato: sab gen 19, 2013 20:18
E' stato un massacro.
Non sapevo a chi chiedere e nessuno mi rispondeva sul forum...
Poi casualmente girando su un forum americano ho trovato uno che mi ha aiutato!
Qui sotto è spiegato tutto
http://finance.groups.yahoo.com/group/t ... ssage/4327
Quanto è brutto avere un problema e non trovare aiuto...
Per fortuna questo è solo un hobby...
